Freeflight 6.6.9 on iOS14
ribas
Hi all
Anyone using Freeflight with iOS14 ? Does it work? Any problems?
I am still with iOS 13.7 just for compatibility but would like to start using iOS14.
OK. I have bought my Anafi in June 2020, so I am using this version and firmware, it´s my first one, no 5Ghz. But I need to hear from other Anafi owners who had tested using iOS 14 with Anafi, before upgrading.
I have Auriga, but I don´t use it, because I don´t have the same control over the image (WB, Manual Exposure settings, Color settings), and 5Ghz support is less important than final image quality. I use P-LOG and color grading in FCP, and I use less contrast -2 and less saturation -2 so that P-LOG works fine.
Yestarday for the first time my ANAFI last firmware and FreeFlightlast version where amazing, because I simply turned ON "Airplane Mode", and "Do not Disturb" simultaneously, what a difference!!!!
But I still need to move on to iOS 14
Hi there, just to leave some feedback:
7 flights so far on IOS14 Iphone8 with zero problems so far; seems normal to me.
Hoping i´m not the only one (y)
From my part it seems safe to update to ios14 for the freeflight6 app
best regards
I have 53 flights totaling 9 hours and 18 minutes logged on 6.6.9 and 1.6.8
it flies absolutely PERFECT.
also I never fly under 40% battery and I store them at 50%
iOS 14.0.1 works perfect as well
Reactions: vekthor
iOS14 works perfect for me, I even forgot to turn off screen recording once, and it recorded 60+ minutes without fail
Reactions: vekthor
