GPS Green indicator is not showing for SC3, but for the drone it is showing a GPS GREEN signal in the FF6 app.
sibujacob
Kuwait
Hi,
Any idea why the Green indicator doesn't show for the SC3 in the smartphone. It showed for first few days. Now I dont see it at all. But the home ( RTH ) works correctly.!!
If you find @MustangPhil suggestion is not the case then you may want to
try a free app for android devices called "GPS Status" which seemed to improve my GPS signal and lock, and easy to calibrate
Very common problem : YouR localisation or GPS is ‘Off’ in your smartphone or tablet...
I knew this information but somehow I was not able to connect. But what I found today morning is a sequence that we need to follow at least on my smartphone connection with the Anafi Thermal. Anyway it worked today morning :)) thanks
Reactions: MustangPhil
