Hello!
henbo
Hi! I'm new here! Just dropped in to introduce myself & beg for help with one of my BEBOP 2 drones which won't connect to freeflight pro
Reactions: Opentheskies
I need help desperately! I own a DJI Phantom2 vision Plus which has never been flown! Two Bebop2's which I have never flown, a Syma XC5, which I have flown & a Syma X56w which has never been flown! As a priority I need to connect my BEBOP2! It has a Skycontroller 1 but I have a Skycontroller 2 for the other BEBOP2 which will connect to freeflight pro on my other S7 phone!
I'm not used to the App connection! I have a BMFA RATING "H" fuel Heli's! I use two JR 9X's & a JR X384 on 35Mg & 2.4 Ghz? Will someone please advise?
With pleasure Hawkeye! My Red BEBOP2 is pre-owned & when I try to connect to the Freeflight Pro app on my S7 phone it wont! My other BEBOP2 connects readily! It is also pre-owned and has a Skycontroller 2 and a pair of FPV goggles!
I'm sorry but I don't have any experience with the SC1, only the SC2.
Hi Hawkeye? I haven't even tried the BEBOP with the SC1? I can't get it to connect through the App on my S7 to show the camera view! The other BEBOP 2 connects without problem to my other S7! I have reset the BEBOP2 & cleared the Data & cache of my phone? The BEBOP 2 shows it's network ID but will not connect!
Hawkeye! I noticed that you have had a similar problem & that you concluded that your error was in the sequence of events? Also please don't forget to put your phone in aeroplane mode otherwise you will suffer a disconnection from your BEBOP 2 if someone phones or text's you?
Welcome from NY! Hopefully someone with some knowledge of the system can help you get the drone up and running.
mrmaxwell
