- Joined
- Nov 29, 2019
- Messages
- 5
- Reaction score
- 2
Ok I try with 2 different sd card, the one given with my Anafi and another one... same results.
Yes it should but its not. So we are trying to find him a solution.I would just get in touch with the retailer and get it exchanged or returned - looks like hardware problems.
It should just work out of the box, with no messing around.
My one also had same issue , whenever i change battery this thing happens. you just have tot do nothing , Keep drone power on , just fold controller and unfold it , FF6 app will launch and you will see video feed again.Hello
Just get my anafi out the box and try to begin my first flight. The take off goes well but on freeflight 6 no pictures as you can see on the picture below. I try to change the SD card and no changes...
Any ideas guys? View attachment 3064
Just reboot your controller only and you will get live feed,[QUOTE = "Tarl, publicación: 26790, miembro: 4767"]
Hola
Solo saca mi anafi de la caja e intenta comenzar mi primer vuelo. El despegue va bien, pero en el vuelo libre 6 no hay imágenes como se puede ver en la imagen a continuación. Intento cambiar la tarjeta SD y no hay cambios ...
Alguna idea chicos? View attachment 3064
[/CITAR]
YI think if you reboot the drone again that could work for you
I don't understand what an SD card would have to do with live video?Hello
