- Joined
- Jul 30, 2018
- Messages
- 95
- Reaction score
- 87
This will obviously be slightly different depending on flight conditions, location, how you fly, etc, but I just put the Anafi up and cruised around like I normally would. This and most other advanced drones have fail-safes, but true flight time is still important to know.
Wow, that's interesting. Do you usually fly in Sports mode?great question, I've been flying Anafi for a year now in all conditions except rain. The best I have gotten was 21 minutes landing with 8%, this was on a brand new battery yesterday. Most flights are about 18 minutes with 20% in the tank. I have taken the battery down to 5% on a flight 20 feet out 20 ft up and only got 16 minutes in very windy conditions.
I believe all my batteries except the new one are getting tired after a year of usage.
Hello fellow Michigander. Sounds like your first one was a lemon. Hope the second one is all set because I think you'll really enjoy this drone. Enjoy your 4th!I purchased a Anafi Extended a couple days ago from BB and had to return/exchange it for another one. One of the battery's was very difficult to install in the drone and the video was choppy when I turned the drone and a little blurry when moving the camera up and down. I also have a Bebop 2 which is a great flyer.
Anyway I see you said you were from MI so am I! I'm between Saginaw and Hemlock.
Glad to know they're not hunting my little Anafi. That doesn't look like the birds I'm seeing. These have red tipped wings. Nonetheless, the theory about the insects makes sense though with all of the air being stirred.Yes, 20-22 minutes is a normal flight time for Anafi.
The birds that orbit your Anafi are swallows. They do not hunt the drone but catch insects that flee from Anafi. Swallows will also fly around my DJI Mavic Pro and DJI Phantom 4 when insects are present.
Swallow - Wikipedia
en.wikipedia.org
You do not see the swallows when no insects are in the air.
That's the wisest way to handle these batteries. Not good to run them down all the time. I'm thinking 20-minutes as well without dropping below 10%.I generally get about the same as Dash. 20 minutes in film mode with 10% remaining. If the Anafi is a long way out, say more than a mile, I will initiate RTH at no less than 20%, preferably 25% if there is a headwind on the return. Naturally the Anafi will work a lot harder in windy conditions so 16 minutes is about what you could expect.
The batteries will last longer if they are not constantly run down below 10%, so I try to plan my Flight Plans at around 15 to 18 minutes at most. I'd never find it if it did an auto-land over most of the terrain I fly.
Yes, you shouldn't make a habit of running your battery down that low. I recommend bring the drone close to the launch point at 20% and landing at no less than 10%. That has worked for me over the years with all of my drones. My Bebop 2 batteries haven't diminished much at all, but I also balance charge them. Wish I could do the same for the Anafi batteries.Within a week of getting my first Anafi (hence very new battery) I had a flight of 24m 21s. The battery went from 100% to 2%. Fortunately I don't have that battery any more as the whole package had to be returned and replaced a few weeks later due to a gimbal fault. Since then I've learned it's best not to use batteries down to almost zero so won't be doing that again.... but at least it proved that the quoted 25 mins flight time is realistic.
Except when it doesn't and just falls out of the sky, which has happened to several people here....... Anafi is smart enough to land even by itself when battery is going below 10%....
I never trust it, maybe that's why never has such problems Extra 2 minutes of flight very rare cost the price of the drone, so at 20% I try to always be not higher then 50 m from land to be sure I'll have time to land safely.Except when it doesn't and just falls out of the sky, which has happened to several people here.
I no longer trust that feature.
Couldn't say for sure (better to ask Parrot support if needed), but as from my expirience RTH alert and battery alarm depends on flight conditions. If not, it will always simply calculate time to show this alerts based only on battery level and distance to start point, but I has already several cases where battery was 40-50% and distance was not too big (around 1 km, not more), but with strong winds around, and I still has this warnings much more earlier then has in normal conditions. By idea, if Anafi could understand that strong wind exists and show alert on it, it's not so difficult to also calculate it's direction (more or less) and then based on that try to predict what time drone will need to return to start point in some direction. But maybe I'm just giving this technics more mind that it has, and occasions that I met are only bugs in program that arised in critical circumstancesDo your tests prove that the Anafi is able to calculate the strength, and direction, of the wind and use this figure to decide when it is time to RTH?
