How to install FreeFlight Pro 3 v5.2.7 on newer Android phones or tablets (tested on Android 10, 11, 12, 13, 14, 15)
Hello @flyingblind Any chance the APK can be updated to Android vs 16? Unfortunately the app doesn't recognize the USB connection when the skycontroller is plugged in. I do have an Android 8 device but that seems to old for this version. Argh, haha!
Update: I was able to load the FreeFlight Pro 3 on Android 8. However the skycontroller is not recogniced by the App when plugging it in. Seems like I can't revert to the old App with my Parrot Anafi USA.
If anyone has any ideas on how to make FreeFlight Pro with Flight Plan work on Android 16 and the Parrot Anafi USA I would be immensely grateful!
Update: I was able to load the FreeFlight Pro 3 on Android 8. However the skycontroller is not recogniced by the App when plugging it in. Seems like I can revert to the old App with my Parrot Anafi USA.
May be you have connected the skycontroller with a USB "charger" cable, it not work, a USB "data" cable is required. Externally seem same but data cable have all required pin connected to usb port.
Good point. I don't believe that's the case though. It's the same cable that came with the Skycontroller, and I have used it successfully to connect the FreeFlight6 App to the Skycontroller.
You will be installing an .apk file and copying a folder named com.parrot.freeflight3 to the /Android/obb folder on your phone.
There are two ways to accomplish this.
Option #1 (easiest) is to copy the files from a Windows PC to your phone.
Option #2 is to use a 3rd party app to copy/move the files on your phone without a Windows PC
OPTION #1:
Download the .apk and obb folder to your computer from the site linked below.
It will download a .zip file. Unzip/extract the file to your computer (usually in your Downloads directory) then navigate to where you extracted the files. You will copy two items to your phone. The “com.parrot.freeflight3” directory into the /Android/obb directory and the “com.parrot.freeflight3.apk” application package into whichever directory you’d like.
Plug your phone into your computer and when prompted on your phone, select “File Transfer”. This will open up the file manager on your PC and should display “Internal Storage” or “Internal shared storage” for the phone’s storage device.
Open the phone’s “Internal Storage” and copy the “com.parrot.freeflight3.apk” application package to your Download folder (or wherever you’d like).
Next, copy the “com.parrot.freeflight3” directory from the /Android/obb directory on your computer to the /Android/obb directory on your phone.
Once the FreeFlight Pro .apk and obb folder are copied to your phone you can disconnect it from your computer.
On your phone you will next launch the FreeFlight Pro .apk to start the install.
With the file manager installed on your phone (usually called “Files”), navigate to the folder where you placed the FreeFlight Pro .apk and tap the “com.parrot.freelight3.apk” file to begin the install of FreeFlight Pro. You will be prompted to allow installation of files from unknown sources. Accept the prompt and proceed with enabling install from unknown sources.
The install will complete and now you should be able to use FreeFlight Pro.
OPTION #2:
Download the .apk and OBB folder from the site linked below.
It will download a .zip file. Unzip the file then transfer the files to your phone or download it directly to your phone and use an app like Zip Extractor to extract the files.
Once the files are extracted on your phone navigate to the FreeFlight Pro .apk file where you unzipped it and open it.
Download the app "Files" by "Marc apps & software" from the Google Play Store.
Its icon is blue with a white file folder in the center.
Disable your built in file manager app. If you don’t do so, then the new file manager doesn't work.
Go to Settings > Apps > See All Apps.
Find the preinstalled file manager app and tap on Disable > Disable in the confirmation prompt.
Follow the instructions on the page linked below to copy the com.parrot.freeflight3 folder to the /Android/obb/ folder.
https://droidwin.com/how-to-access-android-13-data-and-obb-folder-transfer-files-in-them/
FreeFlight Pro should now be installed & functional
Bravo et merci à toi pour cette excellente explication. Chez Parrot, ils sont nuls, ils se contrefichent des gens qui ont des Bebop 2 fonctionnant avec Free Flight 6. Ils sont incapables de dépanner ces personnes, ils m'ont même conseillé d'aller dans un centre de réparation alors que mon drone n'est pas du tout en panne!!!!
J'ai retrouvé mon appli et elle se connecte comme avant avec mon Bebop 2....Merci encore
En fait j'ai parlé trop vite, ma manette Sky contrôleur 2 ne se connecte pas avec mon téléphone Android 15.
Du coup j'ai essayé avec un vieux téléphone Android 12 et là tout fonctionne.... Si quelqu'un sait pourquoi ça ne marche pas avec Android 15, merci de me tenir informé.
bonjour ,
j ai suivi tout a la lettre et quand je lance l application freeflight pro et que je suis aussi connecté au wifi du bepo 2 que ce soit en mode avion ou non il me dit synchronisation impossible il y a juste paramètre qui me renvoie au wifi mais je suis déjà conicité. ??? que dois je faire ?
Hello I tried it but when I open the app the system explain to check my internet connection...Of course internet is perfect at home...I don't understand the problem.
Hello, Same here, did you find a solution for this?
MargieR158
