How to install FreeFlight Pro 3 v5.2.7 on newer Android phones or tablets (tested on Android 10, 11, 12, 13, 14, 15)
Zainstalowałem to w moim telefonie, po prostu mówi, że synchronizacja nie działa
Musisz najpierw skopiować cały folder freeflight3 i wrzucić go do Androida / data / obb.
Bez tej operacji aplikacja nie ruszy na nowych smartwonach.
My Norton Anti-virus software says that apksos site and file are dangerous and will not download the zip file. Anyone else have that problem?
Reactions: flash26
Has anyone else had this problem? When I tried to download the zip file my Norton security stated that it wouldn't because it was dangerous and wouldn't download it and that apksos.com is known for unsafe downloads.
Reactions: flash26
i cant download the file either as it says it's a virus..
help anyone?
I have gotten it to work by installing APKPure (don't allow make and manage phone calls or send notifications, also I didn't update it when prompted). Search for Freeflight Pro and click on "Install". That's it... it creates the obb folder and instlalles everything you need. I haven't tried it on my bebop2 yet, got to get a new battery for my drone. I then uninstalled APKPure when I was finished. My batteries are dead from sitting for over 2 years. Happy flying!
Uruchomiłem go, instaluj APKPure (nie zezwalaj na wykonywanie pokrzyń telefonicznych ani wysyłanie powiadomień, tak jak nie jest to możliwe). Wyszukaj Freeflight Pro i kliknij „Zainstaluj ”. Do wszystko ... dwa foldery obb i instaluje wszystko, czego potrzebujesz. Nie dotyczy tego samego dnia na moim bebop2, należy teraz do góry mego drona. Potem odinstalowalem APKPure, kiedy skończyk. Moje baterie nie działą od ponad 2 lat. Szczęśliwego Łatania!
Antivirus software will always claim it's a virus, because everything from outside the Google Play store, they will consider an unofficial application and a virus. Do as you see fit, I've been downloading and installing everything for 10 years. The Google Play store and institutions of this type do not want you to install anything from outside the store, they consider everything else a virus. Just like unlocking the bootloader, removing the root lock on Android, installing other software, they will consider all of this as improper action. They do not want you to interfere with the system and do anything on your own, you are to do nothing and touch nothing, everything has to be as they decide. and if they consider the application to be outdated, it means that you are not to use it and do not benefit from it. and all this for one reason, they do not want to write updates to old versions of the application, which are no longer popular and which few people use.
help anyone?
don't worry about it, or uninstall the antivirus. Do what you think is right. After all, no one is forcing you to give your login and password to your bank account or your credit card pin number.
Hi I've just got a parrot beebop 2 I can't connect my phone to it , it says I'm connected via WiFi but when I go on free flight 6 app it says I'm not connected, on my app there is no network set up on it do u have any ideas thanks
I am having this problem. I have tried multiple times with different versions but no luck. I am using Galaxy S23 Ultra with One UI 6.1 and Android 14.
App opens fine.
I am connected to drone wifi.
But App doesn't recognize my drone and it says not connected.
App opens fine.
The phone must be connected tò the controller with USB the radiocontoller itself connects to the drone you dont have to connects to the drone wifi
I have a parrot disco so i tried only the flightplan functionality but followme should work also
Mam Parrot Disco, więc wypróbowałem tylko funkcję Flightplan, ale FollowMe również powinno działać
czy zmieniłeś coś jeszcze oprócz dodania planu lotu podczas modyfikowania aplikacji? czy zmieniłeś którykolwiek z parametrów lotu drona lub parametrów lądowania? Dron ostatnio nie lądował zbyt dobrze, albo raczej lądował nierówno na trawie zamiast ładnie szybować przed dotknięciem ziemi.
This parameters are written inside the drone not the app, i only unlocked flightplan and followme
Te parametry są zapisane w dronie, nie w aplikacji. Odblokowałem tylko Flightplan i FollowMe.
Rozumiem, że chodziło Ci tylko o odblokowanie planu lotu. Ale mam innego drona, w którym można odblokować np. limit wysokości za pomocą aplikacji, a gdy rozpakujemy aplikację, możemy po prostu zobaczyć tam wszystkie parametry lotu, takie jak to, co dron robi, gdy traci sygnał i na jakiej wysokości powinien wykonać RTH.
Ostatnio moje skrzydło lądowało brzydko i nierówno, nie dość, że mocno nurkowało w trawie, to jeszcze skręcało w prawo podczas lądowania i łapało trawę skrzydłem. Może moje serwa są zużyte i niesprawne i trzeba je wymienić. Muszę zainstalować nowe serwa Emax. Na razie zrobiłem całkowity reset drona... naciskając przycisk zasilania cztery razy i przytrzymując go, zrobiłem reset fabryczny. Z jedną wadą, usunąłem softmod i teraz po resecie mam soft 1.0.5. Ups.
Hi can someone please help me?
I'm using Samsung Note10+ and followed every instruction but once I try open the application it says "Synchronisation failed. Check your internet connection." and I can't get past this stage despite having a perfectly fine connection.
Any solutions?
Cześć, czy ktoś może mi pomóc?
Używam Samsunga Note10+ i postępuję zgodnie ze wszystkimi instrukcjami, ale gdy próbuję otworzyć aplikację, pojawia się komunikat „Synchronizacja nie powiodła się. Sprawdź połączenie internetowe”. Nie mogę przejść tego etapu, mimo że mam idealne połączenie.
Jakieś rozwiązania?
Czy pobrałeś i skopiowałeś wszystkie pliki do folderu OBB?? Bo to jest przyczyną braku synchronizacji zazwyczaj.
Yes, as I've stated I have followed each and every step including copying into the OBB folder. I also thought by doing this it would solve the synchronisation error but alas, it doesn't.
PiperPilot1
