Freeflight 6 new installation - synchronization failed
MicWaw
Hello,
I bought used Anafi this week. Trying to install FreeFlight 6 on my Samsung S10e android device.
I'm getting well-known synchronization failed issue.
The app was downloaded & installed as APK as the official one is not available for my phone (Android 12).
I guess what is missing is the OBB folder as nothing was downloaded. Just checked in File explorer - nothing created under \internal storage\android\obb\
Can someone help me to get the OBB folder/file so that I can place it manually to be able to launch the app?
Thanks!
Which version of FF6 are you using?
Alternatively I found an old iPhone SE (2016) to see whether App is available for iOS... and yes - I installed it (ver 6.7.5) and no issue with synchro.
Not sure if the official one for iOS contains all the fixes, features in compare to the one moded for Android (FF6_6_7_6_FCC_SE_BATTERY.apk)
Can you advice please?
The official iOS app with not have the modifications, they are not "fixes", e.g. that the modified Android app has.
Ok. So what about missing OBB folder for Android 6.7.6?
Is there any common OBB file across different android phones, versions, etc.? Or it must be downloaded per exact phone I'm using?
Is there any way to get the Flight Plan (add-on) as a download, because unfortunately you can no longer buy this function.
Hello,
Thanks!
Install freeflight6 from Google play, then connect smartphone to computer via cable, allow all permissions to transfer files both on phone and computer, copy directory android/obb/com.parrot.freeflight6 from your phone to computer. Uninstall freeflight6, then copy directory com.parrot.freeflight6 back to phone to android/obb and install freeflight6 fcc. Google pixel 7pro with Android 14
mrwu
