I solved the problem of the filter.
Junwoosung
Setting filters for parrot Anafi.
My solution is simple.
Raise the camera angle in the gimbal calibration menu.
Reactions: chawongyun
Yes, that is the normal behaviour.
Works on my Anafi since July with the original lens cap and with Freewell filters.
Your video has very little to information as to how it was corrected other then interchanging lens cap and ND filters. I fail to see how this corrects the problem.
Well thank you for that. You should edit your post so people are not wondering exactly what you did. It might help a lot of others out if you explained it a little better in your first post.
Reactions: Junwoosung
use android app !! can not find camera angle control key in iPhone app !!!!
gearsgood
