Motor Cut Off
NeilF99
Is there any way of stopping the motors after a landing when they don't cut off?? Seemed to have a perfect flight yesterday, precise RTH was set, good GPS lock etc, flew home flawlessly but after I had it landed (on a hele pad) the motors didn't cut out. It started to do a bit of a jig so tried to press the button on the battery, in the process caught my fingers which caused the motors to stop, but even then it took a while for everything to cut out. When I looked at the log it shows a landing altitude of -1.1 then -0.8m rather than the usual 0m. If anything, I'd have thought this might have caused to motors to cut out before landing. Any ideas?
My understanding (from all the hand landings I do!) is that it uses the bottom ultrasound sensor to detect it has hit the ground /or/ hand, and then switches off the motors.
The altitiude should not make any difference to how that operates.
Reactions: NeilF99
I've had this same thing happen more than once, usually with a bit of wind. After being bitten I won't grab it unless I can get it from underneath. Since then I just hold the left stick hard down and the motors will stop after a few seconds. Whether it dances off the launch pad in the meantime is not predictable. :(
Reactions: NeilF99
Today (22/11/19) updated the software and firmware and had exact the same problem (don't know the hight level, can't find the log file). Already have the Anafi for almost 2 years, it never happened before :-(. Also held the left stick for many seconds down, the motors didn't stop :(. Would be helpful (like the Bebop 2 had/have) to have a programmable motor emergency shutdown button. Any suggestions?
If this happens every time you try to land on a pad your only temporary recourse is to hover it and grab it from underneath and turn it on its side. Then start the process of complaining to Parrot. :mad:
Indeed, that's the only option I have. But luckily after a reset and new calibration I dared to fly again and I did happened a second time. So I guess it was bad luck ;-). Thanks for your reply! Ton
jdodd0224
