My propeller broke off mid-flight
ihavequestions
Actually the first time, I took it out of the bag and I found it was missing a propeller. No harm done. I replaced it. The second time, it must of broke off mid-flight. As I was flying, things were fine, then all of a sudden, it went into a flat spin like how goose died in top gun and luckily it had a soft landing. But it did spin out of control. Again, this was with a replacement prop screwed in properly. After this happened, I examined it and the screw was in, but the propeller somehow detached despite this. Any experience with this?
Was it an original parrot propeller or an Amazon cheap one that is not ‘loose enough’ around the axis ? (I bought a set of copies, and had to re-drill the center to make it fit like the original one).
I had one of those as well - when you mount them they do not move freely. Instead they are stuck due screws. Didn't dare to re-drill them. Any bad drill may cause the prop to break in flight. Did it work out well for you Phil?
These may be useful links.
phile
