- Joined
- Feb 10, 2021
- Messages
- 12
- Reaction score
- 0
When you connect with the SC2, the light on it turns green before you connect the cable to the controller correct? after you connect the cable, does it stay green?I followed that thread and have the s/w working on my Samsung S25.
I have asked on another post about my problem getting the Bebop 2 working with the Skycontroller 2. Using 5.2.7 I can only connect to the drone (via wifi) or the controller(via cable) independently. Once I connect the cable to controller, I get disconnected from the drone.
Oh sounds like your SC2 never actually connected to the bebop, when the SC2 establishes a link it should stay green.Hi, thanks for the reply. No, when I power on the SC2 the light flashes red. When I connect the cable to the phone FFP starts and I can see the SC2 information. Eg firmware is 1.0.9. Light on SC2 continues to flash red.
If I then power on the Bebop2, my phone connects to its wifi and if I hit "connect" in FFP it says "no drones". Disconnect the cable from SC2 and boom, the phone connects to the drone. Connect the cable again to SC2 and drone connectons drops. Drone is 4.7.1 firmware.
That's weird, I don't remember the procedure but I am somewhat sure the SC2 should connect to the bebop automatically, try resetting the bb2 and SC2 and leaving them alone for a bit with no app with the SC2 as close to the front part of the bb2 as possible to minimise the distance between the antennas if you don't see a green light within 5 min post back with your findings!Thanks, I've had the two talking to each other only one time. Never checked the LED status at the point. I flew it around a bit, the battery died. Since then never got the two to work together again.
Reset both drone and SC2, removed all s/w from phone. Started from scratch and still nothing.
If I have some spare tokens after development today I will take a look into why you can't connect, OH I just realised, you said the SC2 self assigned IP 192.168.41.x, that's odd and could point to the SC2 needing a firmware update, my bebop and all bebops I have had self assign the IP of 192.168.42.1, in summary we might need to figure out how to update your SkyController, I will provide you with the firmware image of mine if you need it!Nothing has worked. The SC2 continues to have a flashing red light.
My understanding after reading many posts is that the SC2 connects to the drone through the mobile phone and its wifi. The SC2 doesn't connect directly to the drone.
I even went through a process to change the drone IP to 192.168.41.1 (drone is unix) as that thread said the SC2 only knows 41 ip and not the 42 ip that the drone uses. That did nothing to make things work.
I'm at a loss
A small gift, the root FS of a stock sc2 ArchiveHi Gianni, I'm not sure what IP the SC2 is getting. I was basing that on another post where one person said they changed the drone IP network from 42 to 41 and then their SC2 would connect.
I plan on changing my drone back to 42 since it didn't help.
Possibly a good idea to reflash the SC2 even if it's the same version. I have 1.0.9 now. I'd like to get a copy of what you have and procedure to install from a Windows PC.
