- Joined
- Jun 30, 2018
- Messages
- 584
- Reaction score
- 221
I connect my Mini 4 WiFi only using my mobile hotspot from my phone to get accurate map(s), The Mini displays only 1 green GPS Icon the other is red. I am assuming its because the Mini has no GPS Module. I am currently running the BETA version that was offered as pre-release. I have checked the App Store may times and FreeFlight 6 is not showing up when searched, FF Pro is there.Can anyone confirm everything is ok with an iPad mini 4 ? (Some say Ok, others say it won’t update, others talk about baro problems...).
Mine doesn’t have phone cards and signal neither GPS, but works great on maps with an external Garmin Bluetooth GPS...
So I wonder if it would work with the Anafi ?
Thanks will give it a shot.IPads default to "iPad only" apps in the app store. You need to switch the filter in the upper left corner to "iPhone only" to see Free flight 6 show up.
The controller will fit the iPhone XS Max, however, you will need to take the phone out of a case if you use one.Can anyone confirm if the iPhone Xs Max will or will not fit in the controller's holder? I'm updating my iPhone 5s (which does work by the way) and think the extra screen will make life easier.
I bought an iPhone XS Max and it does work in the case that I bought. Very tight fiit but it works.The controller will fit the iPhone XS Max, however, you will need to take the phone out of a case if you use one.
