Photogrammetry through Pix4D- Anafi images
What software did you use for those outputs? They are different than what Pix4D uses for DEM/DSM.
I always thought we should have a sub-forum for just photogrammetry outputs. Anafi is very well integrated into Pix4D and makes some great orthos and models.
I just mapped Bader Field in Atlantic City, NJ with my Anafi. It was the first airport in the world to call itself an airport. It is closed now. I want to use the obj file to make a model to 3D print it, but I am going to need to also do the old tower which now resides in a museum and then use CAD to try to reinsert it into the current model.
Actually did the image processing using pix4D and the dsm / dtm with contours was generated using QGIS. Also you can get a similar output from Global mapper.
Interestingly I found that AGi mapper was not giving a proper output and giving me errors...Dont know the reason...
simplyAMAN
