Photogrammetry with Parrot Anafi - Pioz Castle
I have no doubt the Parrot Anafi is way simple , easy to handle , small size factor , highly reliable for autonomous Flight missions like photogrammetry and simple way point missions when compared with many other drone manufacturers :)
It is indeed my friend! I am having such a blast doing all these photogrammetry projects😎👌
Hello!
I am new to photogrammetry and I am looking for the best inexpensive way to get started.
I have a Parrot Anafi and from these posts, it appears it will be able to produce the images needed.
Are there free programs or apps available to get started?
Is there a combination of free apps / programs that anyone has found that are recommended? As close to free as possible as I can't afford a lot but really want to get started doing these types of shots.
Can anyone recommend some videos that would help me get started with photogrammetry and mapping etc...?
Hello!
Hey man! You should start by downloading Pix4Dcapture. It's free and you can find in the Play store and Apple store😎
Reactions: sibujacob
I am new too : I took pictures with Pix4DCapture (automated fly and shoot), and I imported theses pictures in 3DF Sephyr on PC.
3DF Zephyr is free, you can do a photogrammetry project, but limited possibilities with result and export...
Reactions: D_The_Producer
I know Zephyr, it is great software. Is not free though, but you can use a free version, which is limited. I would recommend using Pix4Dmapper or Agisoft Metashape trials for better results.
I know this is an old thread, but this is the first time I have tried Pix4DCapture. It connects with my Anafi but it won't fly it. I can manually hover by taking off and the Pix4D app says it's hovering, but I can't start the flight path either from the ground or from hover. I get this screen:
X drone position not known
X mission not uploaded to drone
X drone GPS sallelites (0 found)
! Mission is far away
PeeTeess
