Pre-Flight Checks
Jagerbomb52
Ontario Canada
I check over all my UAV's before I fly and the Anafi is no different. Did my pre-flight and checked the blades. All good. Went for a 5 minute flight and landed. As I was picking the Anafi up from my landing pad I saw what looked like a chip in one of the blades. Sure enough one blade was chipped. It was mentioned on another forum it might have been caused by forcing the blade against the opposing prop screw across the motor. Not sure how that would have happened as I am very careful when setting up and putting everything away. Who knows, just make sure you check out your blades before flight.
Reactions: HiloHawaiian
It does line up with the screw...probably from landing,when motors stop
I got a similar mark/chip but smaller. I have carefully bent the blade and I can't see any cracks, is it safe to fly with this blade? Otherwise it gone be many blades to change in the future.
I get similar marks (but I crashed 3 or 4 times and this causes motors to stop abruptly...)
Not sure a simple landing could cause such dents ?
lustar
