Registration Question
SkyHiBaby
Hello All,
I'm confused about the registration necessary for Anafi. I know you have to register with FAA if any drone is over 0.5 lbs even for recreational use. I would like to record video for commercial use and I know I need a part 107 for that, so if I do that does that mean I just skip the recreational registration part? Do I also have to register with Parrot? Also, what if you flew Anafi without registering, would there be a fine/penalty? Thanks everyone.
The FAA requires you to:
  1. Register your drone when flying under Part 107.
  2. Label your drone (PDF) with your registration number.
Registration costs $5 per aircraft and is valid for 3 years.
In order to register, you'll need to provide the following information:
  • Email address
  • Credit or debit card
  • Physical address and mailing address (if different from physical address)
  • Make and model of your unmanned aircraft
Registering with Parrot is not required.
Any Warranty work they will require a bill of sale.
nikko74130
