SKYCONTROLLER 1.6.2 Update Zoom Fault
GrahamB
Since updating to the latest firmware the controllers zoom function not working.
Anyone else had this problem?
Zoom function does work if used on the phone display.
double check the in app camera settings and ensure that "lossless zoom only" is not set to YES....
Are you trying to zoom in Photo or Video mode? Depending on the resolution that you choose for the Photos/Videos there may be no zoom available. Try a lower resolution and see whether the zoom function works.
Reactions: dashSolo
Yes, that seems to be the problem. The EV changes when I try to zoom. How do I turn off the EV trigger?
-Settings
-Controls
(bottom right of that screen)
-EV Trigger should not be highlighted
Reactions: Ratmir
Brilliant! Thank you zandoli, that's got it working again. I would never have found that myself.
The bonus is that now I know it can be used for EV changing I might find it a useful function.
Cheers.
Reactions: zandoli
I have the same problem and noticed it when I needed it while I was doing a single draw ... ****!
I come to the site for help and ... bim ... there is the answer.
Thanks to GrahamB for raising the question and thanks to zandoli for the answer, I made the correction.
Top forum, thanks to the participants for being friendly and helpful.
stefante
