$100.00Limited quantity
As I understand it Skydio are using Parrot Hardware but with their own proprietary protocol. Shame really as it would have been interesting to experiment with some of Skydio’s hardware with the Anafi.Reserved. Will purchase an Anafi RC too, BUT if I can pair my current Anafi RC to it....LOL...will see...the tech in this thing is amazeballs!!
Thanks, makes sense indeed, smart people ! Even smarter if they've included a power switch so you don't have to dismantle the whole rig if you're using an extra adapter.Just to clear up some questions about the controller here is what another forum member had to say about it.
It’"s their own proprietary protocol. I spoke with Adam the CEO of Skydio tonight and ask about this and they are simply using Parrot hardware as it made no sense to developer their own.
Basically is a partnership on just the RC on hardware. Entirely their own software and protocol and they are not compatible."
Still in testing. Antenna does both 5.8 and 2.4. Limited testing on 5.8...I don't really do distance flying, but signal was full and solid. Manually chose a frequency. Need less wind for more testing.Have you test it ? with booster and without booster.
I have ordered some mini slide switches and will be adding one to my Anafi controller. It should be very easy to do. I will post pictures when I have it completed.Thanks, makes sense indeed, smart people ! Even smarter if they've included a power switch so you don't have to dismantle the whole rig if you're using an extra adapter.
This would be great to see! I would like to do the same thing to my RC. The design of on/off just sucks ballz.I have ordered some mini slide switches and will be adding one to my Anafi controller. It should be very easy to do. I will post pictures when I have it completed.
It should be as simple as connecting a switch in line with the battery positive. I would leave the existing switch connected so that if you forget to manually turn off the controller, it will still power off when closed.This would be great to see! I would like to do the same thing to my RC. The design of on/off just sucks ballz.
Just talking with a buddy of mine, and he brought up a good point about putting in a switch straight to the battery leads....the Anafi RC goes through a shutdown procedure, so not sure how just cutting power would affect it, or if at all. He removed the switch and put in a push button switch for on off, using the existing solder pads for the switch.It should be as simple as connecting a switch in line with the battery positive. I would leave the existing switch connected so that if you forget to manually turn off the controller, it will still power off when closed.
That is interesting that the existing switch was normally open when turned on and closed when turned off. I still want to leave the existing switch in place, so I may have to connect across the terminals of that switch instead of interrupting the battery.Just talking with a buddy of mine, and he brought up a good point about putting in a switch straight to the battery leads....the Anafi RC goes through a shutdown procedure, so not sure how just cutting power would affect it, or if at all. He removed the switch and put in a push button switch for on off, using the existing solder pads for the switch.
