tablet compatability
Noggin
can some one advise me as to is this
lenvo Tablet
compatable with ANAFI / freeflight 6 please getting ready to hit the buy buttons VERY soon fro both drone and table
thanks
in my experience,
Processor- MT8167A/D Processor
- Quad-core
- 1.3 GHz
RAM1 GB DDR3
ResolutionStandard 1024 x 600p
Are most likely very limiting factors!
1Gb Ram is literally nothing, in Android 8 times!
The resolution is poor, the quad x1.3 GHz is , lets say it, not even a Kiri nor a snapdragon
But I do not know the tab, just checking the specs!
I'd say: look a bit more up!
I would say you would have problems with that. Similar specs to the Nexus 7 2012 that I have sat in a draw.
FF6 would not run on it, strangely enough that DJI Go does run on it.
Plenty of much higher spec tablets out there, that dont cost major bucks. I find Amazon is a good starting point.
I use the Huawei M5 8.4" which is a great size. This has a 2k IPS screen so images are nice and clear, plenty of memory, decent spec.
On the phone side, I have several that I run FF6 on without any issues: Huawei P30 Pro, Samsung A9 & Huawei XT2
Some are fans of the iPad and a good few people use them, but they are expensive, as is most Apple products, but you should be able to pick up the mini for a reasonable price, if Apple is what you want.
I always get better results with Android devices.
In the list here:
stands: Lenov(a)o Android 7" Tablet(working)
So you may try to find the post that added this to the list and contact the person for more info
First I used a lenovo Tab4 8 Zoll, which worked fine but I switched to a Samsung galaxy tab s2 9,7 zoll. Great display and very light. It`s also a 4:3 which is IMO the better choice cause the buttons in the screen don`t get in the livestream. You can get it for around 200 bucks. Also the wider frame is better for a sunshade.
I just got a new anafi series bird. Thought this was a 1 minute setup RTF. Wow, I still cannot get these to pair properly. Using controller with the Samsung S2 Tablet 9.6, which I use on every one of my 3DR Solos, with no issues.
I see above the S2 was compatible. Help? I have tried FreeFlight6 and FreeFlight Pro and nada of recognition and the one time it took off and hovered. Thank God! Please tell me wtf I am doing incorrectly. I really need to get used to this bird in the next 2 weeks for a wedding shoot.
Last question. This should be quiet. How quiet for a wedding both indoors and outside? Much appreciated for help.
Sean
I have the same setup with the Anafi and an S2 Tab. Updated to the newest version for the Samsung Tab. In any event, I am having a breakdown because I can’t even get the bird up and running. Hell can’t even pair properly. Can you tell me step by step what you do to connect?
Much appreciated ! Sean
If the Anafi is brand new then I would suggest trying a different device e.g. your phone to see whether the problem is with the Anafi or the tablet. The Anafi uses the Freeflight 6 app not Freeflight Pro.
Whilst the Anafi is quieter than most other similar sized quadcopters it is not silent. Depending on the size of the wedding venue I would think that the sound of it hovering could be intrusive.
Reactions: PollyWannaFly
the host of the wedding need to be aware of the drone plans and possible noise associated with this technology.
I assume it is an outdoor celebration and dont think that drone noise will be a major issue. Depending on the distance. The zoom of this bird is quite good.
Could you borrow a friends Apple mini 2 or newer? It works like a charm, pairing is no issue.
Shutdown all other apps and messages as a precaution, before you start the FF6 app. specially if Cellular is enabled.
I have a dedicated ipad mini 2. No issues. Cheap stuff, for less than 100.00. But eventually I will have to upgrade it.
neauxmad7
