1st flight issue. FreeFlight App keeps crashing...
Razor62
Hi folks! Just got my Bebop 2 charged it up and calibrated the drone. was able to connect to the app and press launch. The drone did as was expected. It lifted off and began to hover a couple of feet above the ground. However, as soon as the drone gets airborne the app crashes. I'm running the app on my Galaxy S8 phone. Is anyone aware of any know issues with this phone and the Freeflight app or am I doing something wrong?
Thanks in advance,
Kevin
Razor62
Answered my own question. Went back to Google Playstore and started reading reviews on the FreeFlight APP. Seems there's a compatibility issue with the software and Android 9 which is what I'm running. There are numerous negative reviews with exactly this issue. ****!!!!
Skydreamer
Hi,if you have old android phone(5,6 or 7)try using it,there is no issues that i know with this versions....android 8 has telemetry issue,as long you fly with your phone installed on skycontroller 2 you are fine,if you switch to FPV(glasses )you loose telemetry(no on screen info)....this is ongoing problem with since april this year and it is still not fixed...it looks like parrot is more focused on Anafi ,how long it will take to fix android 8 and 9 issues nobody knows
Razor62
Thanks so much for taking the time to explain all that. Switched to a tablet for now and I'm in the air.
Funny thing though, this afternoon I was able to connect my phone to the drone but this evening the phone said connected but the app said no connection...Tried restarting the app the Bebop and the phone several times but nope. Was gonna try the Air controller but the app had other ideas... Pretty weird...
Reactions: Skydreamer
Razor62
Thanks guys! Anyone know if installing an earlier version of FreeFlight Pro will resolve the issue? Turning off mini mapping does not correct the problem. I still can't use the tablet stand alone. It must be connected to the Sktcontroller2 in order to work at all.
Lukozade01
