360 Pano from Anafi #1
Jagerbomb52
Ontario Canada
The Anafi that sat up in the tree for 3 months in the Canadian winter still can produce a good 360 pano even if I have to offset the gimble now by -3.50
Really seems as to where I take off from, all level surfaces but if I take off from my sidewalk blocks that have rebar running through them then it is really bad. Can't explain why but 9 times out of ten the tilt is really bad from that spot. Anyways off to the baseball field and all was good to go. Slight adjustment and flew that same battery that spent the winter in the snow for over 18 minutes with no problems.
Reactions: FranoKaaf
clansman320
