ANAFI 1.7.3, ANAFI THERMAL 1.7.3, ANAFI USA 1.7.4, FREEFLIGHT 6.7.0 (IOS & ANDROID), SKYCONTROLLER3 1.7.0
I flew 12 minutes myself give or take. Did notice the RTH was not set to home, so I am happy that I did not go for a range test today :-0 but anyway. Guess it's good! The controller updated as well btw
"-RTH and flight logs can be deactivated"
This is not a new development. This always happens when the drone turns off and drops with a 20-30% battery ... :)
:) Yes they still did not bother fixing the issue with logs only downloading to the phone on the next power up!
Thanks to the many brave souls who tested this first. I may do a test flight tomorrow on both of mine.
Not Brave.... was forced to update o_O
a few hiccups on drone FW update as it did not want to complete on its own
ended up just unplugging battery as i think it was just hung up on reboot
It appears all is well as I flew 3 batteries down to 50% - no issues
Did have issues picking up GPS signal on ground, but up in air ok
I swear i saw at one time 28 satellites - thought there were only 24?
maybe my old eyes are old
Hard to read network setting as i could not see the actual channels
There seems to be battery update too...after anafi+skycontroller update i did additional reset of sc3 and anafi(just in case),hooked up second battery to anafi and turned it on,immediately flickered red green light and then it went trough normal startup procedure.....now we just need brave soul to take anafi to 30 meter altitude and wait for battery to drop down to10%....?
Now that you mention it you may be right on that. First two batteries I saw nothing out of ordinary, but third battery I saw all all 4 lights flash red in sequential order then to normal green
thought it was odd
Performed the update also yesterday, no issues whatsoever.
The GPS picked much more satellites that it used to on the same location (16 where it would not go over 14), no mention for battery upgrade (it did upgrade all my 4 batteries on 1.6.5).
Hello Grenze, can you please explain where you can read the FW version of the battery?
Thanks and regards
Hello dkokki, d95gas & Grenze,
how & where can I read out / recognize the FW version of my batteries?
See # 188 Pilot Grenze has FW 1.6.5 on all 4 batteries, how does he know?
Thanks and regards
Yes got the exact same on my first flight - no GPS lock (as in 0 sats), until I picked it up and waved it around and I got 21 sats, when I normally see only around 17 sats!!!!!
Thanks and regards
See post #6 on the thread below
Reactions: Bruchpilot
Thanks and regards
At dronebook
Anafi GPS chip works with 3 different satellite systems. Third one just became operational. Don't forget to updated Freeflight 6, software may not prompt you but play store will show new update (maybe).
Good evening guys,
has any problems with the new hardware FW Anafi 1.6.7 and FF6_6_7_1_FCC_SE_BATTERY.apk in the camera shake right left in the videos ?
Good evening guys,
Hello, I have had several flights now on new FW with battery mod 1.6.7 and have not seen any camera shacking
All seems to work well, very stable fights
Acquiring Satellite's seems to have improved
Maybe take a quick look at your props?
My props is OK, I wrote because I see video at RTH shaking right - left and another guy had same issue and wrote at fb, but thanks for inform me. Maybe I must Calibrate again
Back in October after previous FW 1.7.3 update I had noticed odd behavior when I initiated a manual RTH
On the drones flight back it stayed on course but drones were rotating left and right
I would not describe it as camera shaking though - I suspect it had to do with GPS, but not sure
Seems to have gone away now - not sure if this is what you are experiencing
FF6 6.7.0 update and firmware 1.7.3
"I also noticed something odd I have never seen before -
When I initiated a manual RTH, on return path it was as if the drone was rotating left and right as if it was not sure of correct heading
Not really pronounced - but 1st time I thought maybe a prop was going bad - distance out was about 1500 feet
this happened on different anafis - I tested all three - as if they lost heading and then self corrected
Did not seem to be a problem at closer ranges though - I was prompted to recalibrate drones after flights too, three occasions"
Ripolins
