Anafi auto-landed for no reason
ParrotAnafiFan
U.S.
Recently flying the anafi at the end of a flight. No 3 min warning to land just autolanded. Luckily at about 8 feet autoland initiated The Motor cutout at four feet, drone found flipped on its back. What is more odd is that. I am unable to turn my battery on or charge it. Reset the battery 5 times to no avail. Something fried on the board or somebody messed with telemetry via wifi injection?
check this log
What the hell?
here you can see battery just completely drop out.
check this log
What the hell?
Hello I had a similar problem years ago where my battery shut down at 13% or so and dropped about 20 feet destroying drone. Im pretty sure it was a bad cell.
I now use Airdata app so I can monitor health of each individual cells. Works vey well. You may want to consider this if privacy is not a concern. I believe that if you use Airdata you may be able to look and analyze the failed flight you had.
Best of luck
Understood and it’s odd unless the battery or a cell completely failed and is no longer up to snuff to accept a charge. My thought was to see if you could review and see any information just prior to when it shut down. Using Airdata or even flight log or black box files via Anafi log program might help to understand what happened
javier51679
