Anafi fail boot after Crash
SecaPilot
Hi there,
I fly bebop2 and bebop2 power.
My friend asked me to purchase an Anafi for him after I lend him 1 of my Bebop2 and learn to fly.
After receiving his Anafi we enjoyed flying together but unfortunately after just few days
he informed me he crashed and that the Drone won't connect anymore.
I checked the drone and visually no crack or visible damage at all except for minor scratch on one of the props.
When pushing the power button, the cooling fan at the bottom will just start to run and that's it, nothing else, no beeping, no more wifi ID visible. Pushing again the power button wont stop the cooling fan, will need to remove the battery.
I know this is very unfortunate and Im in the Philippines, far from support tech.
I dont know if anybody has dead Anafi here..
Just sharing. Probably this will unit will be a spare parts junk.
I checked the motors, resistance reading only for comparisons, all are the same at 4.8ohms, checked connection tightness, all looks good.
Probably board damage or gimbal, not sure, thats why it wont proceed booting. But Gimbal visually looks ok.
Just sharing this experience, any input is appreciated.
Regards,
Eric
PS.
im a seafarer, and will be embarking in a month, probably I can have time for this drone after several months again..
Happy flying...
Reactions: Jmalov
Hi, sorry to hear about you guys crashing.
Anafi is quite easy to take apart to see if any connectors came loose or if the motherboard has cracked.
To disassemble:
Remove all bottom screws.
Peel off the large fork-shape sticker on the top side which has all the wifi-information and then remove all the screws under that.
To disassemble:
Hi,
Will do that, and check for any visual damage.
Will update should I find anything..
Tks,
Eric
did you try Reset....turn On Anafi,wait few seconds then press and hold Power button for 12 seconds,release button,you will see red lights flashing once...try to reconnect
Reactions: SecaPilot
This... I had a dead Anafi after the last firmware update failed to apply, exactly the same symptoms you describe, no wifi no connection.
Folllowed these steps from a video posted somewhere, worked a charm.
Here is the hard reset procedure for ANAFI.
1. Power ANAFI on.
Thanks to your inputs regarding hard reset. Both well noted and here is what happened,
On the 8 second power on reset, i did not notice the steady red light or even blink. It did not respond as stated. Did the procedure several time, nothing really happened.
On the 12 second power on reset, yes I noticed the led turn on in red sequentially and tried to reconnect, still nothing. Did several time also, same response.
No wifi ID broadcast monitored on both procedure.
Thanks guys for the inputs, appreciated a lot.
Will try to dismantle and check the board later.
Will update if any visual damage inside.
Hi guys.
Can anyone help me and tell me how to reset gimbal on parrot anafi.
Cheers
Whats wrong with your gimbal?.....if your gimbal is bit off after crash go to freeflight6/settings/camera/calibrate and readjust camera...you should check the manual,there is procedure you should follow to properly recalibrate camera....to reset camera settings and preferences in same screen scroll down and hit Reset Camera Preferences
Thank for yr prompt reply.
I have try this but still no luck. The motor's on the gimbal run but do not bring it back to level.
Thanks for your prompt reply.
I have try this but is still not working. The motor's on the gimbal are both working but just not returning its self to level.
Do all 3 resets,plug battery into wall ,press and hold power button for 15 seconds,reinstall battery,power up anafi,press and hold power button for 12 seconds to do a hard reset...connect to anafi,fire up freeflight 6,when app starts hit X% icon next to sd card icon,in next screen you will see map and numbers below map...scroll down and you will se hidden Factory (soft)Reset button...reset anafi and right after you will be asked to recalibrate anafi....if that doesnt help automatically then go to settings/camera and attemp to recalibrate from there
Thank you so much for your help, but unfortunately nothing has worked which is really upsetting.
It looks like I've have to send it away .
Kind Regards
Hi there,
Regards,
Eric
PS.
Happy flying...
Hello! I just bumped into your drone story, I happen to own a Parrot Anafi since Dice/2017. Five days ago, on April 08/2024, I use my Anafi to shoot the solar eclipse, I did not fly the drone to shoot the eclipse, I put it on a small table and shoot without flying. After that I took off , the drone was about 4 feet above ground on my concrete patio, I moved back and little to my left and watched the drone coming close to the wall, I totally failed to stop the movement and it hit a wall and it fell to the floor from less than 4 feet high. The motors were like pulsating about once every second. Took the battery off and put it back again and it has been doing exactly the same thing you describe in your story. I tried to hard reset it , but it will not work, not even with two other batteries.
Did you ever find a way to find how to fix it?
Anyone reading this have an idea of how to fix it?
