Hi folks! I apologize in advance for possible errors in the text (this is all a Google translator)), but I hope you understand the essence of the problem.
I bought a drone that was in use and had a non-working gimbal (I really wanted Anafi and decided to take a chance). The previous owner insisted that the problem appeared after updating the firmware, but later I noticed traces of the crash and now I think that the problem was caused by this factor.
So, after turning on, the drone tries to initialize and calibrate the gimbal (up and down in all directions), after it the gimbal is turned off, but the video signal works. The application displays an error - "something is blocking the camera." And most importantly (I tried to show it on the video) - sometimes the transmitted image crumbles and freezes, especially if physically move the camera. And also an important point - just a couple of times the gimbal suddenly came to life for a few seconds and then turned off.
I tried all the simple solutions - reset the settings and disassemble the drone and check all cable connections. Now my suspicion falls on the camera signal cable. Anyone have any thoughts on this? Is it possible to buy this cable separately? Because I couldn’t find it anywhere...
If anyone has thoughts on this subject, please write. And thank you for your attention!
