Anafi instantly lands after take off
Hello all,
I believe I have a very weird problem. I have just recovered my drone from a faulty connection. I performed the calibration & updated the firmware too but now when I am trying to fly indoors as test flight it just lands after takeoff. I am getting vibration error. Can somebody help why this is happening?? Is it because I am flying indoors under a ceiling fan ??
Error snapshots attached.
Yes change your props. I had this error message and changed the props and it went away.
For mine I could not take off from the ground but could do hand launches. After changing the props the problem was solved.
Ok I tried with replacing all the props did a quick calibration went outdoors under 16 satellites ? still the problem persists also sometimes it takes off at last it automatically did some kind of manoeuvres and finally crashed ?
Ooch
Hope nothing else broke.
I wonder if you have a damaged prop motor that is causing the vibration error to go off?
There has to be something out of line for it to give that error.
Did you try a hand launch?
One of my drones would take off, then land also. One of the motors was failing. I could tell by turning the shaft and it was "different" then the other 3. Once I replaced the motor, it would fly again. Apparently the software knew that something was wrong.
HongMunoz
