Anafi surface mount FPC connectors.
Aussiemandia
Hi all,
I've got an unusable mainboard because of one damaged surface mounted FPC connector that mates with the flex cable going to the vertical camera. I also have a motor controller / ESC board that has a charge cable FPC connector that is damaged. These parts are all useless to me unless I can repair those connectors, but I can't do the micro soldering. I do, however, know someone who can do the job, but cannot source the correct FPC connectors do the job. For example, here's a photo of the damaged FPC connector on the ESC board. I need to find the same 20 pin, 2 row surface mounted connector(s) or a very good equivalent.
Does anyone know where to get them? I've looked all over. I would help if I knew who Parrot use to supply these connectors. Molex?
clansman320
