Bebop 2 not turning on
kellow87
Issue with Bebop 2 no longer turning on. Only had a few short flights with it and working fine. First occurred after launching drone then after about 2 metres from ground went back down again.
Tried another working battery and still no luck. Tried holding power button for 10 seconds and no luck also.
Seen mention of replacement board required but wondered if anyone else had any other ideas?
Cheers
Do you really have a 100% working battery?
if you want to reset your drone, you have to hold the power button for at least 15 sec
Yes battery is definitely working as I have tried it in another Parrot Bebop 2 and works fine and another working one in my drone which didn't work.
Cheers
place a fresh 100 percent battery turn it on hold the button for at least 15 seconds and that should solve your issues, if not then its gotta be your motherboard that's where all your power comes from
saveren333
