Today!!
I start getting this error "Check that nothing is blocking the camera and restart your drone.
The drone will keep doing this as showing in the video...
I try for 15 min but there is nothing it just keeps processinghave you tried re-calibrating the Gimbal?
here is the linkThe address for your YouTube video does not work. Therefore, it is not possible to see what is happening. However, it is without doubt a mechanical problem you have with your gimbal. Have you tried gently moving the camera back and forth throughout its range of motion?
Regards Leif.
I tried but same.. It falls from my hand to the floor..Have you tried a gamble calibration? It is clearly failing during start up. Try holding it level off the floor also and do a restart. Have you had a crash recently?
here is the link
About the camera, if you mean the zoom yes it works but to control it up and down no it doesn't work when i start the drone the gimbal move but by my controler it doesn't work..
Latest update is that there is no any solution and here is the conversation..
Just wanted to add that I think you were being a bit harsh on Parrot Support. Think we have all experienced them at some time or another, and yes they can be frustrating to deal with, but had I been in your position, I would not have gone through Parrot.
By your own admission, you dropped the Anafi, causing the damage. There is no way they should be pushed to cover that under warranty.
Personally I would have gone through my home insurance, as they cover items such as this whether at home or away from the home.
I think Parrot support were being fair even pushing it through to see if they could cover it.
Hopefully you will be able to resolve the issue now that you have narrowed it down to where the problem is.
I would put the front cover back on, and move the gimbal almost Slo-Mo to see if you can see where its catching. Try to simulate the movement it goes through when doing calibration, you should be able to see where its catching.
Fingers crossed you resolve it....... these are not cheap toys, so a lot of money just to throw away.
