Curve on horizon
jbuy41
Why do I have a curve on the horizon? Is it the camera or what? See attached.
Depends on what setting you where using. If you had it set to DNG+JPEG wide then yes it will be curved. You need to use a camera profile for the Anafi in Lightroom or simular program. Lots of older posts on here about it.
Thanks. I tried looking for other posts and couldn’t find any.
Camera profile means what? The settings were Rectangle.
So Adobe program that is free for 2 months should work? I tried for 2 hours trying to redeem the coupon and it does not work. Anyone ever try? The user name or SSid not working.
There is a program called RawTherapee. It is a alternative to Adobe lightroom and is free to use. In this post if you read it over it will tell you how to add the LCP for Anafi to the program. Should solve your problems for now.
Thanks. Tried Lightroom and works. But don't need it. Try your tip.
Raw Therepee works too. Had a problem figuring it out.
Thanks Augustine.
eidbrainstorm
