FlightData Manager latest version available somewhere ?
iLouis
Hello,
Just bought a bebop 2 and 4g mods it.
Would anyone king enough to upload the most recent FlightData Manager somewhere ?
I tried the one found here V3 it doesn't work on my windows.
Many thanks in advance,
iLouis
I have it (4.1.8) but, the latest versions wont work with the Bebops.
Find a way to run older version on compat mode. Good luck.
Mine doesn't pull the data from MY.PARROT anymore, I guess this is due to their server shutdown. Is it still working for you?
I haven't tried to use Flight Data Manager in many years. If parrot have shutdown all their servers, then there's no way to get your flight data.
Hmmm, I was about to say well fortunately there is , even if not very convenient: in the Freeflight App, navigate to your flight history and from the top right corner you can request the flight data to be send via email. But I just checked and tried but wasn't successful. Last time it worked for me was on 29th dec 2023.
Very sad!:cry:
Confirmed, when I tried with older flights (before 1st may) it worked for me as well. However I have 2 flights in my history on 1st may, which it will not send for some reason ...
Thanks to this forum I was able to get a copy of FDM from K. Jensen from the link above. Took a first test flight since June of 2017 of my Disco in its new location here in Loveland, CO. Altho I inadvertently deleted the single copy of the video on my server, I DID get FDM to produce the attached TLM data chart from the .pud file I FTP'd off the Disco. See attached.
If you want to know how to get your flight log (its the .pud file) straight off the CHUCK, I'd be happy to walk you thru it. Hint: you login to the Disco's WiFi net and the CHUCK is at IP: 192.168.42.1. I use WinSCP as the FTP client.
Hi Dave, I've been happily going through with my Flight Data Manager. but can't find a way to have access to my Flight Data with Bebop 2. Is there a way that I can get to it locally?
Crankyman
