I got this crach log:
java.lang.NullPointerException: expansionFileDirectory.listFiles() must not be null
at com.parrot.freeflight.feature.expansion.ExpansionFileDownloadActivity.downloadFile(ExpansionFileDownloadActivity.kt:163)
at com.parrot.freeflight.feature.expansion.ExpansionFileDownloadActivity.access$downloadFile(ExpansionFileDownloadActivity.kt:35)
at com.parrot.freeflight.feature.expansion.ExpansionFileDownloadActivity$checkDownloadInProgress$1.run(ExpansionFileDownloadActivity.kt:155)
at android.os.Handler.handleCallback(Handler.java:959)
at android.os.Handler.dispatchMessage(Handler.java:100)
at android.os.Looper.loopOnce(Looper.java:249)
at android.os.Looper.loop(Looper.java:337)
at android.app.ActivityThread.main(ActivityThread.java:9604)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:593)
at com.android.internal.os.Zyg
oteInit.main(ZygoteInit.java:936)
Thanks... But it's crashing.
I've installed the official one, savec the obb freeflight folder, remove the app then replace the obb folder and installed this apk.
When i launch it, i can this the "freeflight 6" logo then it crash..
Which Android version are you using? I am using 11 and 12. Maybe newer versions are not compatible. Are you able to grant all permissions? Are you using exactly the method described in this thread?
What you need to do is to:
  1. Download Freeflight 6 from the Play Store
  2. Open the app and let it load (1-2 sec)
  3. Download a file manager like Solid Explorer and grant all permissions it asks.
  4. Go to your Internal Storage > Android > obb (it might ask for another permission, just click use this folder)
  5. You'll see a folder named "com.parrot.freeflight6" which you need to rename to something else (eg: "com.parrot.freeflight5")
  6. Then uninstall Freeflight 6
  7. Download the modded version and install it, but DO NOT START
  8. Go back to the file manager, and rename the folder to the original name, which is "com.parrot.freeflight6"
  9. Start the modded version.
Cześć,
Czy ktoś mógłby zakończyć, jak włączyć baterię w aplikacji FF6 FFC, jeśli można wybrać wyższą wysokość lotu? Obecnie jestem na 150 m, ale kiedyś, że kiedyś latałem na wysokości 400 mi wyżej. Kupiłem ponownie Anafi i wróciłem, aby móc.
Dziękuję za pomoc.
DId you see my post. It did the same for me until I installed it on my pixel 4a and then moved the install from my pixel 4a to my pixel 9a.
Hi everyone, and many thanks to @AnafiPilot1 and @ds2atc for their work on these modded FF6. I just got a second hand Anafi because I found it to be the best fit for my use for this price. What I did not expect is that most software maintenance from Parrot would be over by now... So, I managed to install a FF6 normal version, then @AnafiPilot1's modded version, but what I really needed was the Flight Plan mode... And I even tried to buy it in the Android store... But after many search I understood that there was no hope to get it officially, and I did not found any unofficial way either. I tried Pix4D Capture, and went around the rectilinear 16MP limitation. Then I have been looking at Parrot's APIs, which looks great, but I do not have enough time and motivation to code something from scratch to use flight plans, and I also think it's much more convenient to load flight plans from the "regular" piloting app. Well, I finally got into this post:
So thank to @ds2atc effort to summarize how he modded FF6, I found a simple way to unlock the Flight plan and Follow me modes. They are both natively included in the app, but just locked until you buy them. Since buying is not anymore possible in Android, I think that it is ok to share an unlocked version. There are a bunch of Anafis in good condition on the second-hand market, it would be a shame to throw them away because of a software problem. They can still be useful to anyone who cannot afford a brand new high-end professional drone. Sorry I'm digressing a bit 😅
So, I made a modded version of @AnafiPilot1's modded version of FF6. For now, I only produced the FF6_6_7_6_SE_BATTERY mod, which I called FF6_6_7_6_SE_BATTERY_ADDONS. I'll make the FF6_6_7_6_FFC_BATTERY_ADDONS as quickly as possible. The apk is available on this drive:
And I also added the necessary obb to install the app, because anyone getting an Anafi right now could be unable to install even the official version... (That was my case, luckily I found an xapk including the obb).
Hope this will help !
Hi Dimdoum, thanks for doing this since there's no way to buy the Addons anymore!
Did you ever get a chance to make a FFC version with Addons?
Thanks for your efforts.
Isaac
op3563
