Help diagnosing mystery crash
darran
I had a mystery crash on a flight the other day. It was a flight plan flight and as it was going about the plan I could tell it was going off course and becoming erratic by the video feed. I tried to land it safely, but by the time I was aware of the issue it had already crashed. Does anyone know what might have caused this. I have included the flight screenshots and also a video of the end of the flight including the crash. I have done this flight plan many times without any problems.
It was higher wind today though...
At the very end you can see it going over a road, but I never have flight paths over the road. The elevation also keeps going crazy at the end. Could high winds cause this behavior?
Here are the last moments of the flight.
Jagerbomb52
Ontario Canada
Without seeing the video my guess would be a broken prop. The erratic flight near the end in my opinion is cause by a broken prop causing it to venture off course and over the road. I have had this happen to me so I am just suggesting that was the problem.
darran
added the video to the original post
speagles2
Adelaide, South Australia
View attachment 6217 View attachment 6218
Very strange. I'd assumed a broken prop also, but the fact that it seemed to recover briefly to stable flight a couple of times, and even begin climbing again, suggests otherwise. It certainly seemed wildly out of control at times. Maybe one or more motors intermittently cutting out? Any evidence from the crashed drone when you found it? (all props attached, can you power it up and do all 4 motors run, etc?)
darran
When I retrieved the drone two blades on the left rear arm were gone (including the screws). A few of the other props had minor damage (think nicks).
I replaced the screws and blades and it flies just like it did before.
Is there any evidence of drone performance being erratic as the battery reaches 20% or is the performance continuous down to zero?
I will say there were winds around 15 mph, but the drone seemed to handle them just fine for around 10 minutes prior to this crash.
Jagerbomb52
Ontario Canada
There should be no erratic flight from low battery at all. I have never had that problem with hundreds of flights. I can almost garantee it was from a broken prop. They are known to brake right at the hub. The screws coming out have my kind of confused though. I have never heard of or seen screws come out in flight before. This might also be the problem that they loosened off and finally fell out causing the crash. The wind really was not that strong, the Anafi can handle wind much stronger. I would keep checking your screws before flight along with any hair line cracks that might be on your props.
darran
I will check them both and also check to make sure the screws are tight. I bought this drone refurbished on eBay and just assumed it was ready to go. This will encourage me to check all of the screws and props. I've noticed that the blades will work if they have cracks, but that is not ideal. The flight this day had pretty much brand new props. Thank you.
It's really hard to know because it kind of wigs out, trys to recover, and then cycles through that until it hits some trees and comes down. When I found it both props and screws were missing on the back left prop - it looked like the one of the screws was ripped out violently. I almost thought the threads were stripped because I could see some silver metallic at the start of the screw hole.
darran
I have seen a hawk flying above it, but you can't see any hawks on the video so I am assuming it is not a bird attack
darran
After reading through this thread, it sounds like one or two of the props could have broken off mid-flight and the drone was trying to keep itself upright, but eventually came down:
parrotanafifan
U.S.A.
Yeah gaining altitude doesn't make sense for a broken prop...
battery firmware issue or connection issue
never fly on auto wifi mode - it's broke
fly on manual wifi mode.
parrotanafifan
U.S.A.
Maybe Parrots firmware tries to let it down slowly with 3 motors, some how if there is a prop out? But still wouldn't explain the rise.
TxArch DroneGuy
