Joystick configuration on Anafi
Monsieurigolo
Good morning, everyone,
I'm about to acquire a Parrot Anafi. Having never owned a drone, I installed the DJI Flight Simulator to familiarise myself with piloting. The mode I'm most comfortable with (by far) is what they call Mode 3.
left stick: front/rear and slide right/left)
Right stick: up/down and right/left rotation
I would like to know if I can set these settings on the ANAFI instead of the default ones (left stick: up/down, right/left rotation; right stick: front/back and right/left sliding).
It's not clear in the leaflet I downloaded from the Parrot website...
Thank you very much for your help
Thks Lizion but as I wrote, I read the Manual. This only thing it says it's :
The Controls preferences set the way your controller behaves. It also enables you to activatethe “Hand-launch” option.
Tap an item option to select it.
Control mode: CLASSIC / ARCADE (only available in flight)
Inverse joys OFF (white) / ON (green)
Special OFF (white) / ON (green)
EV Trigger OFF (white) / ON (green)
Hand-launch NO / YES
I assume he’s left-handed because most people get up and down with the right stick and move back and forth to the side with the right stick.
This is the default setting for both DJI and Parrot.
The operation of the two sticks at Parrot can be reversed.
Put simply, Inverse Joys will give the OP what he wants. "Mode 3"
Default Autel, Parrot, DJI is "Mode 2"
Jo Van de Vyver
