json logfiles date code
IronSky1
Algonquin Il USA
Does anyone know how to interpert the file names so one can figure out what flight data date is contained in .json files they all get downloaded with the same date
1935
The Google file name there is no one who can decode but the date and time of the flight are written into the json file.
Thanks I have been able to read them in Beyond Compare however it does not help with file name when Parrot send all 800 plus flights ate once the only way I can read the file based on name is manually read into Beyond Compare
Then I recommend you use Helmuth's log file program where you can see the Google file name and time of flight at the same time. You can also use the program to sort the files after the time of the flight. It is probably the easiest method, although it may not be ideal for what you are going to do with the files.
Would it be helpful to add a function at "ShowAnafiLog" to rename the JSON files with a date/time stamp in the file name?
Reactions: Landbo
clansman320
