I feel your painSadly, my Anafi is lost to the abyss...
What's the chance of us seeing an updated version at the 2-year mark, around mid-2020?
Cheers.
The drone flew for a few seconds and then control was lost and the drone went into the sea.Sorry to hear about your loss...What happened?
That's too bad...I wonder what happened? Did you share any flight data with Parrot...I realize that the drone is in the sea but I'm assuming (perhaps incorrectly) that some of the flight data would be available in the app on your phone?The drone flew for a few seconds and then control was lost and the drone went into the sea.
The local Parrot support told me to buy a new set instead. Am exploring different options now.
Cheers.
Where can I find the flight data on my phone?That's too bad...I wonder what happened? Did you share any flight data with Parrot...I realize that the drone is in the sea but I'm assuming (perhaps incorrectly) that some of the flight data would be available in the app on your phone?
Jet
You may already know this but in the event you don't.......From the main app screen click on your Parrot Account name..this will give you a display with all of your flights. Then just click on the flight of interest and you'll see multiple tabs along the bottom that will allow you to access some flight info....but not sure if there is anything there that may help you....and it's possible this data isn't saved until you land. With that said I'm assuming Parrrot support could tell you what flight data might be available and where it might be stored...if there is an flight data.Where can I find the flight data on my phone?
Cheers.
That's a bummer....There had been rumors of an Anafi v2 to be released in July/August 2019 but that didn't happen...unless you consider v2 to be the Anafi FPV as it now uses the Anafi Thermal platform (thicker legs, motors positioned at the end of the leg, etc.).
I suspect (but don't know for sure) that once they exhaust the existing inventory of the original Anafi's (v1) units any new Anafi's will be based on the new Anafi v2 platform (i.e., Thermal & Anafi FPV). It makes sense for them to have a single Anafi body/platform rather than multiple bodies going forward.Good point and thanks for reply. Just saw the thread nearby (The New Anafi V2), wondering if I am to get a replacement, how to make sure it's a V2 without spending more for the FPV or the thermal version...
Cheers.
