cheers, was just curious as to when a pilot was out in the field (no pun intended there ), and your phone is set to flight mode (aeroplane mode), would the app utilise your mobile data for your current location or whether it used Google offline maps that I had alread downloaded to my phone, say like if you were using Touch & fly modesNo, it does not, except when you are downloading maps, if you are not using a WiFi connection. So go somewhere with WiFi to do that.
If you have set it to aeroplane mode it cannot use mobile data. As I understand it, the app will download Google Earth imagery when you tell it to. Then you still have offline maps when out of cell range. What I don't know, and am curious about, is how big these files are, where they reside on the phone, and how to delete those you no longer need. They must be rather large, given the ability to zoom very close anywhere GE has good resolution.cheers, was just curious as to when a pilot was out in the field (no pun intended there ), and your phone is set to flight mode (aeroplane mode), would the app utilise your mobile data for your current location or whether it used Google offline maps that I had already downloaded to my phone, say like if you were using Touch & fly modes
cheers for the clarification... I suppose if you get a random opportunity for a flight in an area you don't have maps for then it would have to be a LOS flight..... if I am correct in my assumption...![]()
