No GPS with 1 Battery
Kabous
Hi, I am quite new with the Anafi, why would I get no GPS signal with 1st battery, but when I insert the 2nd Battery, I get full GPS, tested this a few times and every time battery nr 1 don't find GPS while battery nr 2 have full GPS.
Sent from my LYA-L09 using Tapatalk
The only thing I can think of is if the smart electronics in one of the batteries is creating interference on the same frequency range that GPS uses.
Not actually heard of this issue with Anafi batteries or those for any other drone.
As above I have never heard of this before either. You could try to do a hard reset to the battery in question.
Press the power button and keep it pressed: after approximately 12-15 seconds, the battery's LEDs turn on red, one after the other. When the 4 LEDs are red, release the power button.
Reactions: Kabous
Thank you very much, I will try the hard reset tomorrow
Miesher
