Parrot Bepop 1 + Parrot Skycontroller + TAB 7 Pro Tablet incl. Android 14 + Parrot Freeflight Pro... how do I get this constellation to run or fly???
El Gigante
I need help!
After my old Nexus tablet had to be replaced, I bought a TAB 7 Pro. Android 14 is installed on it. Of course, this tablet also needed software to fly my drone. I had great difficulty installing the Parrot Freeflight Pro software.
Now when I start my Parrot Skycontroller, my Parrot 1 and my tablet, I always get the message that "synchronization failed and that I should check my internet connection".
I have really spent hours trying to get my drone into the air. It also took me hours to find information on the internet about how to solve my problem... it's almost hopeless! Ultimately, I'm disappointed that Parrot has completely let me down - after all, I spent a lot of money on the equipment.
I don't understand English very well (I'm from Germany). Maybe someone here can help me to be able to fly my drone again.
Thank you!
I need help!
Thank you!
Read this
Unfortunately, the APK and OBB folder on https://apksos.com/download-app/com.parrot.freeflight3?version=1924916 is no longer available since January 1, 2025 :cry:
Could one of the versions in the picture perhaps work?
Thank you so far! ;)
But I can't do anything with what you wrote to me last time. What should I do now? Where can I get the information on how to get my drone flying again?
I don't have a description of what I can do. 🤷‍♂️
Open the thread and read the messages i posted the apk and the obb links
Oh - I'm further! But:
The program starts... and then I get the message "Synchronization failed. Check your internet connection".
When I check the internet connection, I see that the tablet has a working internet connection. :devilish:😡😤
Why doesn't the program open, why can't I work with it? 🙈
I can't see more than THIS:
Is there any other equivalent software that I can use to fly my Parrot Bebop with the Skycontroller? At the moment, the lack of Freeflight or its non-functioning prevents any flight. Without decent software, investing in hardware is completely pointless. 🤷‍♂️
I just flew my bebop 1 a few min ago, want me to share my app version with you? I think I am running the latest app. I connected direct to drone
i had similar problems google store wouldnt let me install current version of freeflight at all but I managed to get older software installed and working
First you need to download ADB (search it and download it) for windows, install it to c:\adb
then you need the older version of freeflight 3 or freeflight pro .. copy the APK file to c:\
Enable developer settings on your android phone, then enable usb debugging.
Connect your phone to computer/laptop, press trust this device or whatever windows asks...
open a command prompt...(in the file explorer or magnify glass on windows type "cmd". )
in the command line type
CD C:\ADB
ADB DEVICES
. It will start daemon and show your phone as connected. Then after the daemon shows a device (your phone) type
ADB INSTALL --BYPASS-LOW-TARGET-SDK-BLOCK C:\nameofapkfile.apk
This will bypass android 14 security and install almost any apk app on android.
ive got a few older versions of freeflight i managed to find on github if you want i can email to you??
Maybe your version of the app will help. I control my Bebop 1 with a Skycontroller and a tablet with Android 14.
CD C:\ADB
ADB DEVICES
An email would be nice! My email: akernke@gmx.de. I control my Bebop 1 with Skycontroller and tablet (not cell phone) with Android 14. Are the settings the same from cell phone to tablet? I've tried a lot - but unfortunately nothing has worked.
CD C:\ADB
ADB DEVICES
I have now followed your instructions as closely as possible... but it doesn't work because your information is far too vague. What exactly does it say, for example: "Enable developer settings on your Android phone and then enable USB debugging.
Connect your phone to the computer/laptop, press "Trust this device" or whatever Windows asks...
open a command prompt... (type "cmd" in File Explorer or Windows Magnifying Glass.)"
I'm not a developer... and my drone still won't fly! :mad:😤:devilish:
Soz my mistake please allow me to make you a developer...
so first on your phone go into settings and scroll all way to bottom and choose the
'about phone'
find build number then just keep tapping it ... it will tell you when you've become a developer,,
then go back to settings menu and there is a new option called developer settings,, now take a look and enable USB debugging and maybe change default USB as file transfer for copying OBB folder later
now go back to my first post it should be a bit easier now
I guess it's the same app as bebop 2, you can just download the apk on your phone and install it. Then download the zip file on your computer and extract it. Copy the extracted folder (com.parrot.freeflight3) to your phone in "Android/obb/" and you should be able to connect and fly. This method still works on my Android 15 phone.
I've now managed to install Freeflight Pro 5.2.7 with some help. However, the camera image isn't displayed as usual. When I let the drone take off to take photos, it saves the usual fisheye shots
– but the right monitor in the app remains black during the flight.
So I can assume the drone's camera is working.
Can anyone help me?
@El Gigante You could try to turn off the hardware overlays. It might use a bit more power, but sometimes it can help.
First, you need to enable Developer Options (if you haven't already):
* Go to "Settings" on your Android device.
* Scroll down and tap on "About phone" or "About device". (The exact wording might vary slightly depending on your phone's manufacturer and Android version).
* Look for "Software information" and tap on it. (On some devices, the "Build number" might be directly under "About phone").
* Find the "Build number" and tap on it rapidly seven times.
* You should see a message saying, "You are now a developer!" or something similar. You might be asked to enter your phone's PIN, pattern, or password to confirm.
Now, to disable Hardware Overlays:
* Go back to the main "Settings" menu.
* You should now see a new option called "Developer options". Tap on it. (It might be near the bottom of the settings list, or sometimes under a "System" submenu).
* In the "Developer options" menu, scroll down until you find the section related to "Hardware accelerated rendering" or simply "Rendering".
* Look for the option named "Disable HW overlays" or "Turn off hardware overlays".
