Smart Battery charging blinks very slowly
rsvibhadaniya
When i put parrot anafi smart battery on charge its blinking about once in a minute .
I tried resetting battery but still jo effect i tried changing cable as well.
Any body having idea what's happening ?
It is the calibration of the battery that is not in place. The cure should be the following:
1. Discharge the battery to about 5% by letting Anafi standon on the ground.
2. Remove the battery and press the ON/OFF button for 15 seconds.
3. Fully charge the battery.
And it should work again. Personally, however, I would only hover in 1 foot height the first time the battery is emptied again to check the function.
Good luck, sincerely, Leif.
Reactions: rsvibhadaniya
Also in the App navigate to this page and check your Maximum battery capacity. it might be low and may indicate a bad cell and having a hard time balancing the battery.
1775
I will try this step next-day
Reactions: Landbo
