Vertical camera problem
Fobix
Vertical camera error. After a crash, the error appeared ... and nothing visible. If you notice in the middle of the collector plug a pin is missing. The four pins moved, effectively to the left.
It is possible that several such errors have a common cause. The solution is simple ... replace the motherboard.
That happened from a crash?
To me looks like damage from where someone had a heavy handed pry at the connector. Clearly the connector has not moved as all the pins would of been bent, and the fact there is scoring on the connector housing
the plastic is broken and I managed to push back the whole broken piece. I read on the Internet that the problem was with the plug, so I opened it and noticed that the plug is a little crooked. if you mean the protective metal part, I removed it after noticing that the plug is crooked.
You can try to put some "Silicon Glue" properly around the VCAM socket for protection and crashing impact absorber.
Of course, you might do it after the socket fixed.
Reactions: Fobix
igster101
