I’ve been up on several forums, but I’ve never heard such a wish.
The lenses of the drones have a slightly wide viewing angle by default. If you fly high the whole landscape can be seen. If you go farther from the object you would record, everything is also visible. Wide angle of view is desirable in cases where it is not possible to go further than the subject. For example: indoors, in tight spaces. this is especially needed for handheld cameras.
This is not necessary for drones, because there is a movement with the sticks and everything is already in the picture. In addition, the rotors of most drones (with the exception of Anafi) are often seen in the alp position ...
There is a much greater need for a zoom lens, as this allows you to shoot high-flying with less disturbance
