WTB: Parrot Anafi main board / Motherboard
not lucky there are no chips inside for it to store any infomation so the main board has no reason to not work
Are you sure?? Did you try to disassemble it? But I found the chip inside wo XDDD!!!
Reactions: Gipsz Jakab
Since there are two types of opinions on the forum here (some have worked after the replacement and some have not) I think they have used at least two (or more) versions of the MEMS gyroscope built into the camera which only works with the version of the motherboard designed. So there are at least two (or more) types of motherboards as well. There is no other logical explanation for why it works and it doesn't work with gimbal.
Ok, so I recieved the new motherboard and got it installed. Camera works, but gimbal does not. All cables are connected properly.
  • Sad
Reactions: edwardfcy1970
Iapad
