ANAFI 1.7.3, ANAFI THERMAL 1.7.3, ANAFI USA 1.7.4, FREEFLIGHT 6.7.0 (IOS & ANDROID), SKYCONTROLLER3 1.7.0
davyg
Age
68
Stranraer
FF6 update to v6.6.9 and firmware 1.6.8 available
FF6 update addresses
-Battery firmware update is now available again.
-Enhanced compatibility with Drone Logbook.
-Enhanced app stability.
no info for drone firmware though
Am i get it OTA update or i need to download somewhere, fist update that i have for my Anafi.
when you run the FF6 software app then you will see that there will be a "1" next to your drone icon on the home screen..
Reactions: Illirijus89
I think FCC is working again.
Before update i'm stuck in CE channels.
After update i have FCC channels.
I update from 1.6.7 to 1.6.8 with fake gps to Amerika, and vpn to Amerika.
After that i have fcc channels with only fake gps on.
With fake gps off, i have only ce channels again.
Good evening, No Battery updates, only FF6 and Anafi firmware.
Took the new updated Anafi Thermal for a spin. The wind was too strong for high altitudes. Flew around my yard till it used up 85% of the battery. No problems.
Hmmmmmm decisions decisions :) who will be the first to jump
Well have nothing to loose at this point. I upgraded and yes my FCC channels are back and distance seemed good.
Was a quick flight so only went out about 800 feet but solid wifi connection
I have tears of joy running down my face - Dgas seemed to be correct - FW
I did not see any battery upgrade on this
Will do some more testing this weekend
Ok so now if they will just replace my lost drone from Saturday, I will be a real happy camper
Would be interested to see, if you remove the new version of FF6 and go back to using something like "FF6_6.6.2.203_FCC" if you get FCC back or does it stay in CE mode?
Also, in CE Mode, what the signal is like?
I update to, before couple of minutes, didn't tried yet, later, this is what i get of channels.
Without fake gps i get 1 to 48 chanells, and with fake gps to 165. I tries ofcourse in my home. Im from Europe (Balkan, Bosnia and Herzegovina) litlle bit different rules not like in EU countrys.
So what to do, use it with fake gps or not...
Thats a very odd result you got there.
I would of thought as you are EU, you should get the channels from the 2nd Picture; 1 - 11 149 - 165 which would be CE mode
With FakeGPS I would expect to see the first picture giving 1 - 48 which would be FCC mode
Again would be interesting to see what channels you get using the modified APK file FF6_6.6.2.203_FCC
I was thinking the same :)
Well like i said my country is not in European comunity and we have really different laws and here is a litlle bit odd stuff in political meaning so i'm not surprised... So i could try without fake gps to see how is it fly.
And could it be something because i just checked this in my home not outside, probably not but need to ask.
simplyAMAN
