BRC
Back in October after previous FW 1.7.3 update I had noticed odd behavior when I initiated a manual RTHMy props is OK, I wrote because I see video at RTH shaking right - left and another guy had same issue and wrote at fb, but thanks for inform me. Maybe I must Calibrate again
On the drones flight back it stayed on course but drones were rotating left and right
I would not describe it as camera shaking though - I suspect it had to do with GPS, but not sure
Seems to have gone away now - not sure if this is what you are experiencing
FF6 6.7.0 update and firmware 1.7.3
"I also noticed something odd I have never seen before -
When I initiated a manual RTH, on return path it was as if the drone was rotating left and right as if it was not sure of correct heading
Not really pronounced - but 1st time I thought maybe a prop was going bad - distance out was about 1500 feet
this happened on different anafis - I tested all three - as if they lost heading and then self corrected
Did not seem to be a problem at closer ranges though - I was prompted to recalibrate drones after flights too, three occasions"
