- Joined
- Aug 15, 2019
- Messages
- 500
- Reaction score
- 385
Thanks AnafiPilot1 for the response.
Gimbal does move freely with no binding of any kind.
Surface is level using an actual construction level.
Recalibrated 3 times with same results.
I also deleted and reinstalled FF6 on both my iPhone and iPad.
Erased all data from my disk for the aircraft.
And I'm assuming there is no way to "re-flash" the aircraft to download the data again eh?
Drone: 1.6.1
Controller: 1.6.2
Phone: 6.6.1
I was prompted automatically for these updates
Shouldn't the aircraft and controller supposedly be the same version? Theoretically speaking.......
Just read Parrot site. I have the correct versions of firmware and both my devices (phone / ipad) are iOS 13.1.2
You could try reseting the drone - on FF6, click on the drone icon, under the map in the information screen, scroll up till you see the reset button.
Out of interest does the calibration actually complete? It should do normal power up gimbal init, then it should (slowly) rock fully left to fully right, then fully down and fully up. Is this completing correctly, is any of the axis look like it is not doing the full sweep, the movements should be to the end stops of the gimbal movement?
