Anafi Max Altitude Backdoor
SoleFalcon 9
In regards to the 150 meter maximum altitude restriction set on the Anafi, I am considering disconnecting the ultrasonic pressure sensor on the drone itself to hopefully confuse how high the drone actually is. Has anyone tried this or willing to discuss what outcomes would occur?
Anafi has an ultrasonic DISTANCE sensor for measuring the height above ground up to about 11m.
And there is a barometer sensor inside measuring the air pressure for calculating the height and height deviations.
There are other ways to get around the height restrictions, search this forum and you should see another way.
Reactions: Senseicat
In details : create a flight plan , with 1 way point at any ALT. then edit it to ALT ex, 400 meters , start your flightplan , when you reach the desire ALT above 150 meters , fly the heck out of it ... be aware that 400 is the new resriction , and if you go down to 150 geofence will be back to Max 150 meters .did i say meters...
Fae
