- Joined
- Sep 20, 2018
- Messages
- 13
- Reaction score
- 28
Some information that maybe useful after seeing numerous threads on replacing the motherboard and resulting in camera problems. Having repaired a number of these I have accumulated a few spares and found time to swap around boards gimbals and cameras as you can see
Stripping down the gimbals components revealed they are dumb, no chips, only capacitors, it can not be paired with any thing and will work with any replacement board, The Camera again can be used on any main board. The gimbal is controlled by the motor board under the gps Antenna. Now this motor board is paired to the motherboard, I will try and figure out a hack but for now both boards must be purchased together to work the Camera/gimbal correctly, or purchasing separately only any good to use for swapping components with micro-soldering skills, replacing either board separately will result in your Anafi having camera gimbal malfunctions
