Anafi stability issue
Martin31
Hi all
My ANAFI drifts sideways, like swinging left to right to left and so…
It can’t hover properly and i had to « crash land » twice.
I updated everything to last firmware, and calibrated compas before take off.
Any idea what could cause such unstable flight?
Thank you 🙏
Do you make sure that the Anari has a good GPS lock before you take off?
Also are you using OEM propellers and have you checked them for hairline cracks and that the motors are free to rotate and have no play in the bearings?
Thank you, I think I have now a checklist. I Check all that and tell you.
I checked everything, remove all blades, put them back.
I went in an open field for less magnetic interference, calibrated compass…
And it flies normal again.
Thank you for your advice. 🙏🙏
Reactions: Crossrich
clansman320
